High Pressure Power Steering Hose Connector
I had the high pressure steering hose from the rear of the steering gear box to the bottom of the AC cooler blow while on the road today. I am not sure if this is a stock setup or not since I have a Hemi installed but I think it is. I am trying to get the quick connect fitting loose near the cooler with no luck. I bought some sleeves that snap around the tubing but have not been able to push the sleeve into the fitting to release the tubing. Any suggestions and does the stock 2011 JK have the hose in the same configuration.
Well, I got it apart. It ended up being just a wire clip behind the cap. Still need to determine if this is a stock hose since I called the only dealership open and the parts department guy was less than helpful.
