hitch wiring kit
hitch wiring kit
Where is the "plug n play" for the hitch wiring? ? Thought it suppose to b n taillight, even looked under trunk area, no where to b found
You can order a T-connector that connects in the drivers side taillight. I ordered from JC Whitney. Was about a 10 minute install.
http://www.jcwhitney.com/curt-t-conn...149y2011g671j1
I Used the Mopar 7 pin harness kit
You disconnect the left tail light, plug it into the new harness, plug the new harness into the taillight. This ties you into the signal/brake/running light circuits. The 7 pin the harness also runs to the battery for trailer power and into the cab for a brake controller.
