Hood flutter and outside temp
Old Sep 1, 2013 | 03:34 PM
Hbone's Avatar
Default Hood flutter and outside temp
I don't know if this has been noticed but I installed new hood latches and everything was gravy until the outside temp here in Dallas rose above 100 degrees. Then it came back like a bad STD. I leave for work at 4:30 am when it's 75-80 degrees , no flutter. If someone came out with a hood latch rubber band thing that was not affected by temp I would be happy. Z-ties make it easy but I think this would fix it.
Old Sep 1, 2013 | 04:44 PM
Woody's Avatar
Vet Army
Get the Daystar replacements for about $25 But you don't have to remove the lower bracket like they tell you to (PIA) just put a pair of vise grips on each end and twist, old ones pop and remove easy
Old Sep 1, 2013 | 05:33 PM
SaharasotaJK's Avatar
X2 on the Daystar Hood Wranglers. Not fluddered since I installed here inFL it gets hot too, stock look.
Old Sep 1, 2013 | 05:54 PM
JS1122's Avatar
I've been looking into the drake hood pins
Old Sep 2, 2013 | 04:56 AM
Moab13-Sask's Avatar
To eliminate the flutter (no matter the temp) remove the spring attached to the hood. No flutter at any speed or even when meeting a semi. Hood does not vibrate either so there is no paint rubbing. The spring is only a convenience factor.
Old Sep 2, 2013 | 05:05 AM
okie's Avatar
Exactly. I've had my spring removed for a long time now, no flutter and absolutely no problems.
Old Sep 2, 2013 | 06:03 AM
Gman*2007's Avatar
The daystar hood wranglers are the way to go. They are a little tight at first, but limber up some later. No hood flutter at all.
Old Feb 22, 2014 | 02:12 PM
scotiez's Avatar
I just installed the Daystar Hood Wranglers here too. Its a great and low cost fix for the famous Jeep Wrangler Hood Flutter. They are def very tight at 1st but ill loosen up over time. I know cause I had these on my old TJ and they work great.
Old Feb 22, 2014 | 02:13 PM
bombout800's Avatar
All you have to do to stop flutter is remove the good spring. Did mine and haven't had any since
Old Feb 22, 2014 | 02:49 PM
karls's Avatar
Necro thread warning....
I removed my spring because of folks like the ones above who claim zero flutter. I can personally attest that it is not true. You will still have flutter. It isn't as significant but you will still get it when you pass a semi and occasionally on the highway.
I've got 95k miles that I put on my jeep, so I'm not basing my decision on a day or two of experience.
