Hot as hell!
Old Nov 18, 2008 | 06:01 PM
cmpmacchia's Avatar
Originally Posted by whtIwrk4
Out of warranty. I have 68,000km's. I may have something back there blocking it. I once took my glove box all the way out only to find some papers and 2 CD's that I was missing sitting on top of the blower motor. Guess I have to stop being lazy and have a look.
Huh? I'm not following? Are you having a problem with your heat?
Old Nov 18, 2008 | 06:04 PM
whtIwrk4's Avatar
No, no. The heat and everything works fine. It blows up at the windshield fine as well. When I turn the knob all the way to the defog position (right), I can feel it hit the detent at the end but whe I let it go, the knob just turns back a 1/4" or so. It just doesn't stay turned all the way to the end. Still blows at the windshield though. Guess that's why I haven't looked into it. Not causing any problems, just a little annoying.
Old Nov 18, 2008 | 06:07 PM
cmpmacchia's Avatar
Oh, Ok I'm following now. Still think you should bring it to your dealer hopfully the'll give you a break. Glad to hear the heat good! 60,000K wow! How has your Jeep been so far, any issues?!
Old Nov 18, 2008 | 06:23 PM
turtoni's Avatar
Here's my *hot* air circulation tip:
Put the circulation onto the feet setting.
On this setting you'll get a small amount of output to the windscreen which is enough to defog it but you'll not activate the air conditioner (saving gas) and soon be warm as toast.
And if it's really cold you won't crack the windscreen as it warms up.
I always used to circulate the air to the windshield in my previous vehicles until i learned that the air conditioner comes on in this position with the JK even if it's switched off..
Old Nov 18, 2008 | 06:28 PM
whtIwrk4's Avatar
Your right, it does come on. Most vehicles are like that these days. You can crack the windshield by defogging it? Didn't ever think about that, but makes sense. I also didn't know you get air flow at the windshield when set to the floor. I'll have to try that.
Old Nov 18, 2008 | 06:42 PM
turtoni's Avatar
Yeah i feel some output to the windshield in the foot setting with the fan only cranked up half way or less.
I read somebody cracked their windshield going from ice cold to hot in the windshield circulation setting.
Old Nov 18, 2008 | 07:06 PM
Matt08jk's Avatar
Last december I was driving from vancouver to winnipeg....it did a good job, but in the late evening in -25 to -30 I was getting some frost creeping in on the bottom corners of the windshield.
gonetoshoot's Avatar
Mine does the same thing!!!
Old Nov 18, 2008 | 07:08 PM
whtIwrk4's Avatar
Weird, I wonder what it is?
Old Nov 18, 2008 | 07:14 PM
scouter4life's Avatar
The heater is certainly somrthing that has always been done well in Jeeps. My YJ had floor vents only and I would burn my feet with it on low.
