How do you KEEP the JK running FOREVER?
Reputation has it the 4.0L is bullet proof. I know. I had a TJ. Not sure if I'm speaking too soon, but we haven't seen just how far the 3.8L can go. Perhaps it's just as good or better or worse than the 4.0L TJ. I don't know.................
Any other advice, thoughts, opinions, comments, and tips are very much appreciated.
If you want to run your JK forever then buy spare parts cheap as you can find great deals. For example, you can find engines and trannies for $600. Let the other guy spend tens of thousands on a Hemi and dana 60 running gear.
The not driving thing.. keeping miles low only works on high end cars.. BMW/PORSCHE/BENZ and obviously higher than that.
Domestic and even a high end VW -- low miles on blue/black book only bumps value few hundred .. compared to thousands on an exotic.
So drive the beast!
So drive the beast!
I've heard (from Two Guys Garage on Speed TV) that most engine wear occurs on the crankshaft journals and other bearing surfaces on startup. Once the crank is spinning it is not really coming in contact with the metalic surfaces as it 'floats' in a film of oil. Any way to minimize startup friction, especially if your Jeep sits for days at a time without being started?
I have added this to the engine oil threads:
The engine number is located on the rear of the block, just below the cylinder head, on the drivers side. There will be two sets of numbers. The first set is the engine number, the second set nearby is the last 8 digits of your VIN.
The second character in the engine number represents the manufacturing plant.
S = Saltillo
T = Trenton
Check your engines. Maybe we can see if the plant location has anything to do with engine failures.
Mine was assembled in Trenton.
S = Saltillo
T = Trenton
