How do you take apart drivers door mirror?
Old Nov 17, 2012 | 09:40 AM
maine07jk's Avatar
Default How do you take apart drivers door mirror?
Does anyone know how to take apart a drivers side door mirror? How to I remove the door mount section from the shaft that attaches to the mirror and the outer plastic? I can't get them separated.
Old Nov 18, 2012 | 07:45 AM
pfd1980's Avatar
Its a muthafuker.. Good luck.. I tried to do this to install a mirror relocate kit and i soon gave up
Old Nov 18, 2012 | 07:58 AM
JK_hammer_47's Avatar
I was able to separate mine after hours of pulling and banging the bolt, which I backed out a bit and took a mallet to that with a piece of wood over it. I ended up with a fat lip when the damn thing finally gave in when I was pulling up on it. Good luck with yours, and wear a face protection if your yanking it up.
Old Nov 18, 2012 | 02:52 PM
williamsc75's Avatar
Spray some WD40, use a rubber mallet and hit the mirror frame. I had the same problem and that worked. It's a bitch cause the aluminum in the bracket gets corroded. Good luck!
Old Nov 18, 2012 | 03:11 PM
maine07jk's Avatar
Well......I just called it. I just used the mirror I just got that has some scratches on the plastic. When I knock this one off with a tree again, then I can try to separate it then!
Old Nov 18, 2012 | 03:15 PM
1995nscajeep's Avatar
I gave up 3 years ago tried again last year didn't work its destined to stay where it's at and I have no problem explaining that to the police officer who pulls me over for no mirrors and doors
Old Nov 18, 2012 | 03:46 PM
profebill's Avatar
Just take the bolt out from underneath and turn the mirror halfway back and smack the bottom the the mirror with your hand. Hard.
Old Nov 18, 2012 | 04:00 PM
maine07jk's Avatar
I tried smacking it hard with more than my hand and it didn't work!
