How do you turn off the airbags???
If you unplug the wire going to the seat belt on the B pillar it will disable the air bags. From what i can tell the seatbelt will ratchet tighte to protect you from the airbag. if its unpluged the airbag light comes on the dash. I regularly use a 4pt harness and the idea of an airbag blowing with a harness on i'm not sure what would happen.
Never mind that statistics show the effectiveness of these features. Everyone knows statistics lie!
Must maintain Purity Of Essence!!
Do what you want. Just accept the risks and get on with it.
I have not seen sensors in the seats. I personally removed the passenger seat last week and there are no harnesses or anything that attach to the seat, 4 bolts and it's out. The driver's seat may be different but there are no sensors on my passenger seat, 10 2dr sport- no options.
someone writes, doing fatal crash investigations for years tells a real life real world different story. The smoke you see after an activation is non toxic powder. And, the urban legend of getting stuck in a vehicle that goes into water as an excuse to not wear a seat belt does not happen. Maybe once in the past 50 years and the occupant was dead upon impact anyway.
I disabled my air bags, removed the seat belts, chopped out the factory "roll cage", disabled the anti-lock brakes, reinforced the "collapsible" steering column, removed the emergency brake, disabled the TMPS, and took out all of the running lights, brake lights, and side markers.
LOL. Open the hood. Disconnect the battery. Open the fuse box. There should be a yellow plastic tab, it will have 2 ten amp fuses in it. Use a screwdriver to pry the tabs apart that hold the yellow tab/fuse holder in. Pull up on the yellow tab. It will pull both fuses out at the same time. These are for the airbags. My air bag on the driver side is not working properly and the light was constantly coming on and off chiming the whole time. Pulled the fuses and no more on off chime. The chime is enough to drive a man crazy!! Note the air bags WILL NOT WORK. The occupant restraint module does not have power to it any more.
Hope that helps...
Hope that helps...
after I lifted I thought about disabling the airbags but now wonder if they don't disable when in 4Hi or 4Lo.
I banged into a tree pretty good with stock bumper and thought they would go off but didn't. Maybe it's because I wasn't at speed but it was a hard hit.
I think all newer airbags from the last 10-15 years only deploy in crashes at pretty high speed. They will do more harm than good at low speeds and they significantly increase the cost of repairs if they do go off.
You are correct. In the newer JK's there are no sensors in the seats. If there were you would see a light that would come on if no one was sitting in the passenger seat indicating that the air bag was off. That is why any child seat has to be attached in the rear. Again, whether you wear your seat belt or not or endorse air bags or not is your business. I have seen that both have saved many lives and prevented serious injury. I have never seen anyone driving a Jeep in my area not wearing a seat belt.
Apparently mine is equipped with the sensors. Seems strange that they would leave the sensors out of some models if they make the airbags safer. 2011 JK Sport with 24s and power convenience group.
