Sponsored by:
Sponsored by: DashLynx
How to find out if i have 373 or 410 gears
Old 11-20-2008, 01:58 PM
dlincoln91's Avatar
Default How to find out if i have 373 or 410 gears
i have a 2008 jk sahara unlimited
it has the towing package
im just wondering how to know
it has dana 44 rear with dana 30 front
Old 11-20-2008, 02:08 PM
RedneckJeep's Avatar
It has the 3.73s.
Old 11-20-2008, 02:34 PM
Originally Posted by AussieJK
ALL RUBICONS HAVE 4.10 gears..... from factory
That's right, but the Xs and Saharas HAD the option for 4:10 in '07 IF you ordered with the towing package. That was changed in '08 so that only the Rubicons could get the 4:10.
Old 11-20-2008, 02:58 PM
HarryBallz's Avatar
If you know your tire revs/mile you should be able to figure it out by comparing road speed to RPM in top gear (or any gear as long as you know the ratio).
Copy from another of my posts:
MPH = RPM * 60 / (Rear Axle Ratio * Trans Ratio * Tire revs per mile), or
RPM = Rear Axle Ratio * Trans Ratio * Tire revs per mile * MPH / 60
Top gear ratio is 0.84 for the manual & 0.69 for the auto.
Tire revs are 661 for stock Sahara w/ 17 inch wheels, 653 w/ 18" wheels
Old 11-20-2008, 03:05 PM
Originally Posted by redx08
sorry for not being clear. what i meant to say was for 08 wranglers, Only the rubicon models came with 410 gears. Now get your panties out of a wad.
Not wadded at all. Just making sure the OP knew the difference. That's all.
Old 11-20-2008, 05:15 PM
blkpearl's Avatar
it should be 3.73, and upgraded tow package had reciever, and 7pin plug to support towing a trailor with trailor brakes....some will even have the 4pin......but the rating changes with the trailor brake option....for the unlimited with the jeep class I light duty 2000lbs, with the class II medium duty 3500lbs......attached are the pics of the dana 30 on the top, and dana 44 cover on the bottom. hope this helps
Old 11-20-2008, 05:25 PM
BlackNorthernJK's Avatar
or just break out the jack and a crayon....mark a line on your rear axle with it lifted in the air spin a rear tire two times and count how many time the axle spins....if it's 3 turns and almost a fourth 3.73's if it's definately 4 turns and a little more 4.10's
Old 11-20-2008, 08:42 PM
hawgrider1200's Avatar
Default gear ratio
sumbuddy said if u input ur vin number on the internet jeep web site sumwhere they'd tell ya which one it is
My sticker is in the glove box and it said I had 4.10's on my X
Old 11-20-2008, 11:39 PM
BadDrivr's Avatar
What he said. just be sure youre in neutral or ya may end up watching each wheel turn while the drive shaft stays put.
Old 11-21-2008, 01:07 AM
Yall, it's an '08 NON Rubicon with the towing package. Unless somebody changed um out, it aint got 4.10s, it had 3.73s.
Quick Reply: How to find out if i have 373 or 410 gears
