How much space between bump stops on stock rubicon?
I have looked high and low and can't find this info anywhere. Does anyone know how much the space measures between the landing pad on the axles and the metal cup that holds the, um white mushy thingy on a stock Rubicon?
Also, are the front and rear the same spacing when stock?
This would be good info for anyone who is wondering how much lift they actually have, but I can't find it anywhere...
The local dealer doesn't have a Rubicon on the lot so I'm not able to just measure one. Mine has aftermarket springs and I'm trying to guage how they have affected my uptravel vs stock.
Thanks. BTW, I don't think 6" sounds right. Stock Rubicon shocks only have 8" travel, so if they were sitting at 6" extension they could only droop another 2".
So that means stock Rubicon with its 7.9" shock travel has...
approx 3.75" compression and 4.25" droop on front suspension.
approx 5.5" compression and 2.5" droop on rear suspension.
This is good info for anyone looking to guage how their lift has affected their articulation over stock.
Originally Posted by 5.56x45mm
Just measured my bone stock 2011 rubicon 2 dr:
Front = 3.75" from bottom of metal cup to pad
Rear = 5.5" from bottom of metal cup to pad
