How much time? (driveshaft
Old Feb 23, 2011 | 03:07 PM
Schwheelz's Avatar
Originally Posted by Youri
My rear driveshaft did that, actually it was ripped more. I ran with it for a month before I got a tom woods driveshaft.
I just kept adding grease in there.
I don't think it will blow up your t-case if it seizes up. It will just twist the driveshaft itself. The aftermarket ones would blow up your t-case.
Plus, you'll definitely know it's about to go when it starts squeaking a lot, so it's not like it's a time bomb.
What did you add grease with? If you mind me asking
Old Feb 23, 2011 | 03:11 PM
Schwheelz's Avatar
What replacement driveshaft do ya'll recommend?
Old Feb 23, 2011 | 03:16 PM
interceptor_1972's Avatar
I'd use one of these:
with a needle fitting:
I went with a Coast 1310 (front and rear), but there are others as well - JE Reel, Tom Woods, Tatton just to name a few. But when you do get an aftermarket driveshaft, be sure to get adjustable control arms as well.
Old Feb 23, 2011 | 03:50 PM
Dronac's Avatar
I wonder if it's possible to reseal a torn boot with shoe gloo? I'v heard of it used for CV boots with success. Thoughts?
Old Feb 24, 2011 | 05:33 AM
Dronac's Avatar
I used the grease gun that interceptor_1972 posted.
Also, I know you're supposed to get upper control arms when you upgrade to an aftermarket shaft, but I haven't done that yet and I've driven 70+ without any noticeable vibrations. That's with 2.5 inches of lift and a tom woods shaft.
That'd be awesome if you could use some kind of glue to fix the rubber! I'd love to fix up my old shaft to keep as a spare, just in case (even though you replace yokes with aftermarket).
I read about people using it on various car forums for their CV axle boots. They inject some grease and patch it with the glue. I can't imagine it wouldn't work on our JK's since the problem is just excessive pinch wear on the rubber causing it to tear.
