How to prove the differential is OPEN without taking off the differential cover
Old May 23, 2011 | 12:48 PM
ronjenx's Avatar
Originally Posted by Rockroaster
Last weekend I installed some 5.13's in my axles. I just noticed this thread, and got me to thinking.... I am supposed to have a limited slip in the rear of my JKU. But while in there, the carrier looked the same as the front, and I saw nothing that would make me think it actually had a limited slip. What should I have seen in there that would identify this as a limited slip versus being open? Anyone have pics of what one looks like? All I noticed were the spider gears. Wish I would have thought about this while I was in there, but didn't even hit me as I was trying to do a re-gear and lift in one weekend. I don't have a jack here at my place, its in storage as I am between places right now.
Chock the front tires and use the jack that's in the back of your Jeep.
Old May 23, 2011 | 01:06 PM
The_Yeti's Avatar
I have a LSD in the rear but have been told that the "clutches" in it are worn out so it acts as an open differental.
i dont know if thats true or a possibility here but seems plausable.
Old May 23, 2011 | 01:27 PM
ronjenx's Avatar
Yes. It is possible.
Old May 23, 2011 | 01:55 PM
33 williys 77's Avatar
Hell make it easy on yourself if it's a auto powerbrake (never mine I see where it's 6 speed) the hell out of it on a wet surface then let her ripp
If you have a single track for the first few feet until the ( TCS (Traction Control System),kicks in it's open
Old May 23, 2011 | 02:22 PM
lopezv123's Avatar
Originally Posted by wolfmanii
I bought my 2009 JK brand new, on the sticker it says it has limited slip differential on
the rear axle.
Recently, I added ARB differential cover to my front and rear axle. To my surprise, I found
the differential looks like an open one, several of my friends checked at that time and they
agreed with me.
Because JK is my daily vehicle, so I had the put the ARB differential cover on, and because
I did not have camera at that time, no picture is taken.
I am planning to ask Chrysler to install this missing option on my JK, but I need to prove it
by a local Jeep dealer. QUestion is: is it possible to confirm a differential cover is OPEN
without taking off the cover.
Call Chrysler and get the build sheet.
Old Jun 15, 2011 | 06:42 AM
Rockroaster's Avatar
So I jacked mine up last night, left it in park, and both rear tires spun in opposite directions... But there was a ratcheting sound as they spun... Open or limited?
Old Jun 15, 2011 | 09:00 AM
bowerss2's Avatar
It is not a LSD. It probably has some sort of locker in it if it makes a steady tick tick tick as you turn one.
could be a "lunchbox locker" are you the first owner? could also be a "detroit locker" if its a Lunchbox locker pull that garbage out right away.
this is a lunchbox locker. It replaces the spider gears. They are cheap and easy to install but they are also hell on the diff carrier. They can lock up unpredictably and can lead to sporty handling in the snow.
this is a Detroit locker. It works in a similar way but is WAY WAY better.
it could also be a worn out lsd or an open with something that is just ticking.
Old Jun 15, 2011 | 09:07 AM
No locker. Original owner, and just put some 5.13s in about a month ago myself, and saw what others above mentioned, a carrier that looks open. But as some have said above, even though it may look open, it could still be a limited slip, so doing this test, and receiving a click noise makes me think it is.
Old Jun 15, 2011 | 06:41 PM
genesbro's Avatar
Best way to check is to put it into neutral and have both rear wheels off the ground. Spin one of the tires by hand and if the other goes in the same direction then it is limited or locked and if one goes the other direction then it is open, no guessing envolved.
