HVAC heat cold blend operation
Old Mar 22, 2026 | 05:46 AM
Waywardtravel@yahoo.com's Avatar
Default HVAC heat cold blend operation
Hello, I have a new to me 2016 JKU. It didn't have heat. I replaced the driver's side blend actuator and now heat works great.
Weird part "to me". With the AC turned off and blowing the coldest ambient air temp. If I rotate the dial just one index to warmer, it rapidly changes to heat. Is that just how it is, or do I need to go through a calibration to get some form of blend from ambient to hot?
Thanks
Old May 15, 2026 | 07:40 AM
staroct22's Avatar
An HVAC blend door system regulates cabin temperature by controlling the ratio of hot and cold air mixed together before exiting the vents. It operates by manipulating a "blend door" (or flap) located inside the dashboard HVAC housing, positioned between the heater core (hot) and the air conditioning evaporator (cold)
