I Purchased a 3 piece hardtop for my 07 JK X, I have a problem
I have an 07 JK X Unlimited, I purchased an 09 JK three piece hardtop and have a problem..Everything lines up and fits except one thing, The center lever to lock down the two ft lift out sections is where the problem is..The 09 U Windshield frame fastener is left by 1 and 1/2 inches of the 07 Position. I have not pulled down the trim to check if it is bolted down or welded..Before I do, can someone answer if they know? I have tried to check the web but not having any luck..I may just pull the trim down tomorrow and see, if no one can help me here..All else fits great and both windshield lock down with no problem..I don't think it will be a problem, but I am not ready to take it out in the rain...Thanks for any information you can supply..
It's bolted in just like the driver's side and passenger side that you have visible. The problem is more that the threads inside the frame are part of a nut. You can easily drill two holes and move it over, cept not certain what others have used to secure it since there will be no threads in the new location. Many have done this before....just can't recall what they do to secure it or about the threads.
I wouldn't worry about driving with it like that at all. You might just test with a water hose to verify you have no leak at all. I've driven with mine not clipped there due to leaving a spider web shade or similar still attached to the center loop and had zero leaking issues at all, but leaks seem to be hit and miss in general from jeep to jeep.
ped I seasoned in a Griddle and these are the pic's of the inside and outside of the Hardtop. Hope she dosn't leak taking her to the dealer for the recall Tuesday. Thanks for the input!!
Well I took it to the dealer and one of the two recalls were done. I also asked about the top issue about the u fastener. I was informed that it has been enough of an issue that Chrysler has a fix. now they make a wider fastener to address the problem..Killer part is they say it would be $215 parts and labor...I think I'll pass but I forgot to ask how much just the part is..I need to call them back and find out.
I could be wrong but I think I've seen folks just unbolt it, move it to the right spot, drill it in, and go from there. I'd want the proper trim to go with it but I'm a little particular. I'd bet you could get that loop, footman loop?, from eBay or something and paint it yourself for much cheaper.
Dinky Dau (07-26-2019)
Flip it over towards the drives side and rivet/bolt it back together.
Mopar sells a kit that includes the trim.
hard top adapter
