Identifying JK7 Dana 44 Gear Ratio
"Take the number of teeth on the ring gear and divide it by the number of teeth on the pinion gear. In this instance of a Dana 44 4.09 gear ratio, there will be 45 teeth on the ring gear and 11 teeth on the pinion gear. 45 divided by 11 equals 4.09 (45/11=4.09) and thus you have a 4.09 ratio"
Dana 44 Gears
Dana 44 Gears
Dana 44 Gears
Dana 44 Gears
Thanks! It is indeed a 4.09 or more commonly known as a 4.10 geared Dana 44! I figured it out by spinning the pinion and measuring the amount of turns the ring gear made.
Are those gears different from what comes in the Rubicon?
The Rubicon 4.10 gears are 41 on the ring and 10 on the pinion.
