Rust touch up paint
Old Feb 25, 2014 | 04:23 PM
jfrohock3437's Avatar
Default Rust touch up paint
Time have a good way to clean this up? Small amounts of rust around the screws are driving me mad. It's only that windshield bracket and no where else on the jeep.
Old Feb 25, 2014 | 04:40 PM
Ryan0260's Avatar
Try spraying them with wd40 and scrub with a firm toothbrush. Make sure to let them soak before you scrub them.
Old Feb 25, 2014 | 04:42 PM
augichef's Avatar
Had the same thing happen to my silver jk, I had it covered under warranty..
Augi
Thanks. I'll try that.
Old Feb 25, 2014 | 04:45 PM
This is a 07 and I can't imagine it's covered by warrantee
Old Feb 25, 2014 | 06:18 PM
augichef's Avatar
Even if it's not my paperwork showed that it cost around $120 to repaint both sides.
Augi
Old Feb 25, 2014 | 06:45 PM
big c's Avatar
Take a rag and some rubbing compound. Remover the bolts ( I did one at a time) rub with compound and then use a good lithium grease spray. Spray the area in and around the hole and put bolts back ... Worked for me has not come back
Old Feb 26, 2014 | 01:22 AM
Thanks. By rubbing compound do you mean a mild abrasive cleaner wax?
Old Feb 26, 2014 | 06:01 AM
JeepWranglerNation's Avatar
Default Personal Preferences
We would scrub the area then use Krylons rust prevention paint.. then maybe several coats of either bed liner of conventional paint or maybe the hammered textured look..(off road armor look)
