Instrument Cluster or something else?
Old May 20, 2021 | 07:11 PM
Eddie Legorburu's Avatar
Default Instrument Cluster or something else?
2009 JK Sahara. After sitting off in some rain. I open the door and no odometer display. Engine turns on with no problem. But Instrument cluster is dead and wipers are on, head lights are also on but switched off. Also locked in park. I suspected the an issue with the cluster after some research which I disconnected and then reconnected. After I did that everything works as it should. Works well as long as the Jeep is on or only turned of for a few seconds. Only after letting the Jeep sit off for a few minutes the problem comes back.
