Interior Front Door Panel Removal?
Old May 27, 2007 | 08:37 PM
DBB888's Avatar
So you did it with the window down? and pulled it out in one piece? Or you took the window out first then the interior panel?
Old May 27, 2007 | 08:56 PM
yellowjeeper85's Avatar
This might get a little complicated since i don't have pics but it was like this. the window is held into the regulator by a white plastice clip that clips a big tab through a hole in the bottom of the glass for the window. In order to get the interior panel off, you have to roll the window down about 1/3 of the way, then unscrew all the screws for the interior panel. Pry on the panel until you can see the white clip that holds the window, shove something behind the interior panel where you are prying to now pry up on the white clip intil you can slide the window up freely. Slide the glass all the way up and use tape or something to hold it all the way up. Then wiggle, jiggle, shimmy, shake, pry, coax, pull, and convince the interior panel out, this is a bit tricky since the regulator is connected to the backside of the panel. if you're car savvy or just pretty handy, don't be afraid to do it, but just don't be expecting any peice of cake removal either. Good luck
