Jeep JKU is whistling at startup
I think I have also noticed it is much more likely to happen when it is really cold (Under 40 degrees )
I have noticed that it appears to have this issue on cold mornings. That being said it will probably be screaming like a banshee tomorrow with temps. projected to be 9.
A friend of mine has a 2012 rubi. He had a weird whistle noise he couldn't figure out. Never would have guessed it, but it was coming from the PCV system. The dealer replaced that under warranty and it fixed his whistle noise.
Anyone been able to find out?
I know this is an old thread, but I cannot find any resolution to this problem. My JK is now making the identical noise. Only at startup when its cold - absolutely brake related.
noise
Also idler pulleys go bad sometimes making a grinding sound while engine at idle. Very easy to replace.
Hope this helps
I get a whistle on cold start up too. as soon as I touch the brake pedal, lasts abought 5 seconds. it does it if I brake hard too. I think its a vacuum leak on the booster.
