Jeep JKU is whistling at startup
I have a 2012 JKU Rubicon (MWF3) with aprox 28K miles. In the past week I have noticed an intermittent whistle when I start up the jeep. It is a definite electrical high pitch whistle from the dash. I also notice that there is a red dot that sometimes illuminates when this happens (Red Dot to the right top of dash). It usually happens when I start the Jeep and turns off after a few seconds but sometimes It will stay on for a while.. I will shut the jeep off, and restart and it will still be on.. it WILL shut off after a few seconds though 90% of the time. It has also happend after driving maybe 1/8 miles and stopping at a stop sign. It is usually when the jeep is a cold start..
I will try to post audio / video but wanted to get this question out there.
thanks all
thanks all
Thank you for the reply, I do notice the red dot light up for a split second at startup all the time.. when I hear the whistle it stays lit for extended period of time.. maybe I have an issue with my alarm system?
I don't have any info on that for ya, I don't have the alarm system like you do. It just lights up with the remote start and it illuminated when I had a fresh key cut but not programmed.
I'm sure you'll get more info, just give it a minute and folks will show up.
I have a 2013 JKU with about 19,000 mi. and my Jeep has begun making the whistle also. It will usually do it do not long after I start it up. It does it when I start it with the key and I do not get a red light or any other sign that something is wrong. It does not do it every time and it started about 3 weeks ago. It usually only lasts about a second or two, however, today it lasted for about 5 sec. but it trailed off and got more quiet as it did. Dealer has never heard of it and of course I can never replicate the noise when there so.......
After going out to start my Jeep this morning I discovered it was my brakes making the noise. I would step on the brake to shift it into gear and I would get the whistle. It could clearly be heard outside the Jeep as well as inside. I was able to reproduce the whistle a few times by stepping on and off the brake. After about 5 min. the whistle sound can not be produced anymore. Does anyone know what this is?
Check under the hood with the engine running and move around some vacuum hoses. Just a thought.
Ok, I was finally able to record it.. I was wrong on the red light, it comes on for a split second every time i start the jeep.. but this sounds happens on cold starts every 2 or 3 times...
I have attached a youtube video
https://www.youtube.com/watch?v=Z6QjafQ-jAk&feature=youtube_gdata_player"]https://www.youtube.com/watch?v=Z6QjafQ-jAk&feature=youtube_gdata_player
Is this the same as you are hearing ECUPirate?
Anyone know what this might be?
The sound on the YouTube video is the same as I hear. Mine does not usually last that long but that is the sound. If this is a vacuum leak is this bad? Never heard of this before, what is the usual repair like?
