Jeep will start but guages blank, stuck in park, wipers won't turn off??
#51
UPDATE: The battery checked out OK. It was not fully charged so I charged it up and reinstalled. They did not have the right battery connectors so I used the same ones but they seemed tight and didn't move. Same results! I went though everything again and noticed that she does come out of Park and will go to any gear. Of course she starts fine and I double checked the alternator which is working fine. The lights just come on but you can't turn them off. The wipers just start but can't be turned off . The radio lights up and works. The air is on low but you can't change it and the air Cond won't come on. This is so strange. Any other ideas?
#52
It sounds like symptoms of a bad TIPM to me. Do you have JSCAN or similar that can check the enhanced codes (advanced scan in the JSCAN app)?
#53
I was wondering about the TIPM. No I don't have anything but a regular code reader. I was going to see if there were any codes to read this morning. I was also going to see if most of the issues have inputs from the TIPM to see if there was a correlation. They are expensive!
#54
Thanks for the replies! The simple reader I have does reflect any codes. I found another place that had the right terminal clamps and got those installed no change. I did a hard rest on the TIPM with no change. I went through all the doors and pulled/wiggled on the harness and connectors in case there was a short there and no change. To add to the symptoms the brake lights work but the turn signs don't? I sent a note to MAKS since I think if I get a TIPM it would be from them. I explained the symptoms and asked if that was what a typical bad TIPM. I looked at their videos and that is why I did the reset and checked the door wiring. The Jeep was running fine, parked in a garage for about three or four weeks and I went to take her out and this is where I am. Glad it didn't happen anywhere else. Any other ideas?
#55
What about ground issues. When I installed my driver deadman pedal (good to have) I disconnected the studs with the grounds by the footwell to mount the pedal on and the wipers started running all by themselves with no key in the ignition. I disconnected the battery to stop them and once the pedal was fully installed reconnected battery and all was well again.
#56
I had checked the grounds by the battery. I talked to Macs and I have send them the TIPM to be tested/rebuilt. They said these are typical symptoms so we will see in about a week or so when they test it.
#58
UPDATE: Unfortunately the rebuilt TIPM did not change anything. I talked to MAKS and they agreed that the charge should just be for testing and the rest has already been refunded. I would highly recommend them if anyone has a TIPM problem. So now I am going to drive her to the dealer so they can hook it up the diagnostic machine. The dealer is a lot closer than the one auto repair place I know that does a good job. Hopefully the issue can be found!
