JK Oil Burning?
I read on another thread to use 30 instead of 20. We use the 20 because that is what the manual tells us to use. The jeep goes through about a quart and half every 2000 miles. Not sure if we should try the 30. He claims of course if we use a thicker oil it will patch the problem but theres still a problem. On top of that I have the gas tank that overflows and a crazy shake at 40mph that came out of nowhere. Did I mention he loves my jeep
Also check the spark plugs for unusual build up. Check for weeps and leaks if you haven't already.
A dealer should replace you gas tank (search for the many other threads on this) and the crazy shake could be as simple as a wheel out of balance. Look over the rims, you may notice a spot where a balance wait "used to be". Otherwise check the ball-joints and other components for unusual wear.
Enjoy!
see the post above you; change your PCV valve. Cheap, easy, and has helped some (not all) posters with unexplained oil loss.
Enjoy!
Enjoy!
https://www.jk-forum.com/forums/show...ling-PCV-Valve
Crawl under you JKU if you see any leaks. I did an recent oil change myself a few weeks back. I noticed a dripping under my JKU thought I maybe did not tighten the drain plug or oil filter tight enough....ended up being my Slave cylinder failed.
After I got the slave cylinder fixed at the dealership, the next day my wife noticed one drip spot on the carport concrete again under the JKU. I thought the dealership gave me a bumped up slave cylinder. I peek at the bellhousing and no leaks. take a peek under the oil pan. No leaks. Then I check the oil level it is below the safe level...
So, I thought maybe it was burning oil or my oil filter is loose. I got thinking I couldn't burn that much in 500km of driving. Crawl under and see this mess!!!
I thought at first it was the timing cover leak....but a few members pointed me to look at the crank seals....
It got towed on Friday to the dealership and I still have not got word from them what the issue. To be honest this mess only left one drip of oil on the carport. I would have thought more with this mess. I figured I lost about 1.5liters of oil. Could have ended up worse.
Wow this is a big mess
No he already checked under the JK for any leaks. I don't even leave oil spots in parking places. No idea where the oil is going but at least I am not alone with this problem. He does all the work on the JK everytime vehicles go to the dealer they just come back more messed up. For example my ebrake still don't work after the whole cable freakin snapped still drifts. Forgot to mention that problem too
I have that same mess. Let me know what happens....please PM me about it if possible.
Thanks
Thanks
