JK Rubicon rear axle question
Alright guys I have a question that I haven't been able to figure out through my Factory resources(I am a DC Metro CJDR Parts Manager) so I am turning to you. I bought a JK rear Rubicon assembly from a wholesale customer that was involved in a wreck. As it turns out the housing itself is slightly bent and I am concerned about using it in my DD 2017 JKU. So my options are to try and salvage this axle with a new housing (preferred method) or putting a Truetrac in the back of my 44 and re-gearing.
With that said, the part number for a Rubicon rear housing is the same through MY2015. In 2016 they changed part numbers on the housing but I cannot figure out what the differences might be in them. Also, the cost on the bare housing is half of the price on the 2016+ versus the older housing.
Any thoughts?
Any thoughts?
Anyhow, to the OP, I'm not aware of a change that occurred with the rear axle housing. Aftermarket support for those axles are all the same, I think, regardless of year, so to me that would indicate they are functionally the same. You could try calling the folks from East Coast Gear Supply. They are pretty tuned into Dana factory axles. Someone there might be able to answer your question (they might even be able to get you a new housing).
jdinny (01-08-2018)
He already bought the rubi axle, you'll have to argue about something else ...
The choices seem to be:
1. Pay to gut and straighten the bent rubi housing.
2. Buy a replacement rubi housing to dump all the parts into.
3. Sell the Rubi44, Pay for a truetrac plus install in the non-rubi 44.
Get quotes and see how much difference there is in the prices. Assuming number 2 isn't too much more expensive than 3, I'd go for 2. (from my one experience with a bent housing, 1 and 2 were about the same cost, so a new housing makes sense)
No idea on any differrences between those years, but I'd guess the half-price housing is a misprint?
The weak link in any JK rear axle is the axle shaft flanges. They will bend no matter the spline count, stock or aftermarket shafts, etc. that being said, your best money is spent on an ARB & matching 35 spline shafts. The non-Rubi housing can be easily upgraded as such, as well as the Rubi housing. Stock rear 44 is nearly 60 strength in many areas.
