Junk cv joints
Old Jun 18, 2011 | 08:30 AM
Kojack's Avatar
Default Junk cv joints
Anyone else have problems with the stock cv joints on their unlimited? 3300 kms. Yep 3300 not 33000. My brand new 2wk old jk shit one out. Anything to help peice of mind?
Old Jun 18, 2011 | 08:38 AM
wayoflife's Avatar
JK-Forum Founder
is your jeep lifted? and, when you say it shit one out, can you be more specific?
Old Jun 18, 2011 | 01:41 PM
Kojack's Avatar
The cap came off and the joint is flopping around in the axle.
No lift. Only 2wks old with no off roading only fire roads.
Old Jun 18, 2011 | 02:03 PM
Mark Doiron's Avatar
Originally Posted by Kojack
The cap came off and the joint is flopping around in the axle. No lift. Only 2wks old with no off roading only fire roads.
Is this on the driveshaft, or is it an axle U-joint? If it's an axle U-joint, check out this thread:
https://www.jk-forum.com/forums/showthread.php?133359-Axle-u-joint
Old Jun 18, 2011 | 02:56 PM
Kojack's Avatar
On the axle. I'm getting it covered under warranty or else. My jeep is bone stock. And I'm going to get the dealer to tack the caps on. That way no poppy off when driving. I bbet that's the loose clunky feeling I was getting in the wheel to. Every now and then over a bump, I would feel a clunk.
Old Jun 18, 2011 | 05:33 PM
GOOVERIT's Avatar
That would be a true definition of a warranty problem. Could be a Monday build.
It more then likey wont happen agian. I have 63000 on mine and wheel it a little hard. rocks, small creeks, hill. You know, up and over most thing that come up.
Old Jun 18, 2011 | 09:06 PM
Coley's Avatar
One of mine was toast after less than 1year and 25,000km. Random, but relatively cheap fix.
Old Jun 19, 2011 | 03:13 AM
Kojack's Avatar
That's what I figured. It's an isolated incident. But I'm getting them to tack weld the caps for peice of mind.
I don't want to get stranded up in the bush.
