Just Drained and Filled Front and Rear Diffs for the First Time...WOW
Old Mar 30, 2011 | 12:51 PM
EzK's Avatar
EzK
Manual Trans = Synchromesh type. Ex: Dealer stuff, Pennzoil Synchromesh, Royal Purple Synchromax
Old Mar 30, 2011 | 12:59 PM
Mark Doiron's Avatar
Originally Posted by AHunter
and keep 75w90 in the front?
In '07 Jeep specified 80W-90.
Old Mar 30, 2011 | 01:01 PM
Originally Posted by Jiblet
75w-140 in the rear for towing. (if you have Trac-lok you need the additive)
Don't use additive with virtually all synthetics in the LSD. They work fine without it.
Old Mar 30, 2011 | 03:25 PM
JK-Ford's Avatar
yup, unless... are you towing in 4wd?
I'm no profesional. But if I planed on towing or pulling on anything. Or if I did a lot of offroading in 4WD. I would run the heavy oil in both diff's.
Old Mar 30, 2011 | 03:43 PM
u-joint's Avatar
Last I checked, Royal Purple did NOT meet Chrysler spec.
Old Mar 30, 2011 | 04:44 PM
jeeperjkjeeper's Avatar
i have had good results with the following:
ID:	143947Click image for larger version
ID:	143948Click image for larger version
Old Mar 30, 2011 | 04:52 PM
Shell's Avatar
Thumbs up
Originally Posted by Uneasy Rider
No BS huh? Yeah right.
+1
Old Mar 30, 2011 | 05:16 PM
EzK's Avatar
EzK
www.royalpurple.com/transmission-chart.html
It doesn't list it under Jeep or Chrysler but under Dodge it does say it's good for transmissions with MS9224 requirements(their own claim); which is what the nsg370 requires, right?
Chrysler does a good job of keeping us scared on fluids, that's for sure.
Last edited by Moochie; Mar 30, 2011 at 06:01 PM. Reason: Please, no clickable links to non sponsors
Old Mar 30, 2011 | 05:28 PM
sa29560's Avatar
It doesn't list it under Jeep or Chrysler but under Dodge it does say it's good for transmissions with MS9224 requirements; which is what the nsg370 requires, right?
Scared or not, what they charge to service a tranny is cruel. Where they mounted that exhaust doesn't make it much easier.
I went looking for the Royal Purple stuff and could not find it anywhere locally.
Ended up going with some of the Pennzoil MS-9224 stuff and it works great. Tranny work is in my future, and getting that exhaust out of the way is well worth it
Old Mar 30, 2011 | 05:54 PM
u-joint's Avatar
http://www.royalpurple.com/transmission-chart.html
Thats odd it's listed under Dodge...
Either way, I looked over their bottle in the store the last time I was buying, and it didn't listed the MS9224 spec, so I didn't buy it. I went with Pennzoil, it was cheaper anyways.
