Leaking pinch seam?
Hey guys, I posted a while back that I kept seeing water coming out of the passenger side rocker area, finally noticed it's pouring out of the passenger punch seam right behind the front passenger tire. The left pinch doesn't seem to leak at all, just wondering if this is normal or will my rocker panel eventually rot out because of this?
Cheers guys, thanks
Jay
Cheers guys, thanks
Jay
Cheers guys, thanks
Jay
Cheers guys, thanks
Jay
I have not seen this happen on mine, but in my opinion I would rather have the water run out rather than sit inside the panel. I would be mostly concerned if salt in the winter sat in there......but it doesn't snow in Vic does it? Seriously though, just rinse it out good whenever you wash it.
Yeah the water thing isn't something I would be overly concerned with. Something you could check if you look behind the rocker or underneath and see if anything is missing. ie clip, nut/bolt possibly water is just getting under the fender liner in which case is normal and possibily the other side would leak too if it had a place to get in.
