Lets Solve the Stock Springs Question
Old 06-09-2013, 07:30 AM
  #691
Ncb
Ncb's Avatar
Plus, what good is a stock suspension with very little droop on the axles? I installed taller coils on a two door (for a friend) and the shocks had very little droop left in them at ride height. Might be good at the mall, but no bueno here on Colorado trails.
Old 06-09-2013, 07:35 AM
  #692
JK Inspired's Avatar
Originally Posted by Ncb
Just a difference in the term. A lift involves longer shocks, bump stop, etc. It changes the dynamics allowing larger tires to fit under the flares.
Longer OEM coils on a stock suspension doesn't change the up limit or down limit of the axle. To me that's a ride height change.
An increase in "ride height"= lift, be it a suspension or body. Said increase with "longer shocks, bump stops, etc," I would refer to as a suspension SYSTEM. Kinda like doing bench presses- might be good for SHOW, but does nothing for the GO!
Old 06-09-2013, 10:00 AM
  #693
zstairlessone's Avatar
Of course if you are Bjoern Werner then bench presses give you go
Old 06-09-2013, 10:26 AM
  #694
Safe to say, he does pulling movements (back, glutes, hammies) in a 2 to 1 ratio compared to pressing.
Old 06-09-2013, 12:17 PM
  #695
JLsJK's Avatar
I just want to throw this out there in case it could help someone wanting shocks when replacing coils. I put on 19/59 coils and stock shocks for a while. I had very little down travel so I started measuring and researching shocks. I didn't want to add bumpstops and I didn't want my springs to fall out. The shocks that fit this setup more than any other were the old man emus. The ones before the nitro sport and not the long travels. The fronts had 9.25 travel which left me with 5 up and 4 down. The rears have 9.5 travel which put me at 5 up and 4.25 down travel. Makes for a nice ride that's practical and gives you back more than you had before the coil change. Hope this helps someone. Most of the other shocks that would add needed down travel also needed extended bumpstops. These worked for me. I will say I had to extend brakelines because after the shocks I couldn't get the tires off the ground when lifting from the frame.
Old 06-09-2013, 12:30 PM
  #696
karls's Avatar
I did 17/58's with 1.5-3' 5100's......I need 1/2" of bumpstop and I can completely droop the axle without unseating a coils. This isn't even 'full' droop yet, quite a difference in just a shock change.
Sent from my DROID4 using Tapatalk 4 Beta
Old 06-27-2013, 10:10 PM
  #697
JK_YV's Avatar
14/56 (2D) vs 10A (4D) 19/61
ID:	472675   Click image for larger version
ID:	472676   Click image for larger version
ID:	472677   Click image for larger version
Old 06-28-2013, 07:03 AM
  #698
yo_marc's Avatar
^ That looks great
How does it ride?!
I've got 18/59's in the garage... Been going back and forth on whether or not to install them in place of my 14/15-55's. Those before/after photos are very helpful. I'm dead set on not going 'too' high for stock wheels and tires.
Old 06-28-2013, 10:01 AM
  #699
JK_YV's Avatar
Originally Posted by yo_marc
^ That looks great
How does it ride?!
Just do it!...
Old 06-28-2013, 10:23 AM
  #700
dawgtre's Avatar
I just ordered a set of 18/59s to replace my 14/57s. Hoping for 1-2" to make room for some 295/70R17 Cooper STTs. Will post pics when done.
Quick Reply: Lets Solve the Stock Springs Question
