Locker light flashing....
Allright..... I seem to have a problem. I ran a trail last week and flipped the switch on my lockers. They locked up fine... Both lights went solid. When I disengaged the lockers the rear locker light continues to blink. I cracked open the rear diff. Lock and unlocked the locker and it works fine and all lights are solid except when disengaged the rear light still blinks and will not stop unless vehicle is powered off.
Anyone have an idea? Any body else experience this yet?
JK-Forum Founder
if it's still blinking after you turn it off, that typically means it hasn't disengaged. this is a very common problem and one of the biggest thing i hate about the factory lockers.
if the locker is in fact open and locked then it is your sensor. it has a plunger on it that should move up and down (down is locked and up is unlocked). you can not get the sensor out without moving the gears out just a bit. it can become stuck or bent in my case with new gear install, or the internals can go bad on the sensor. i had to replace mine if you can't get one from the dealer let me know by pm and i will help you locate one.
