Low tire pressure light?
THe low tire pressure light came on after two nights in upstate new York , I checked my tires they aren't low , did the change in temperature set my light off ?
As it gets colder, you will require a little more air pressure, cold air contracts, hot expands. When its cold out, I can get a lower pressure indication and after driving for say 30 mins my tires heat up a bit, the lower pressure indication will turn off.
Add some air and it will turn off. Always check your tires pressure when your tires are cold or cool.
