MAF and TB cleaning?
Old Jan 28, 2013 | 04:48 PM
notsoricer's Avatar
Default MAF and TB cleaning?
i called to make an appt with the dealership for a 15k service. i do everything myself but i figured i need to eventually get my rig in the system so if anything ever happens they can't say i never brought it in for maintenance. i have 16k and asked what needed to be done and they told me oil change, tire rotation, MAF cleaning, TB cleaning, injector cleaning, air filter... all i want them to do is change the oil and thats stretching it. I'm obviously going to pass on everything else because i just rotated tires and have a new air filter in my garage. how do i clean the maf and tb? and do i just run a treatment through my tank for the injectors? my diffs should be good until summer so ill leave that alone so i can save up for new covers too. what do you guys recommend? thanks!
Old Jan 28, 2013 | 04:53 PM
jeeperjkjeeper's Avatar
Seafoam treatment works great imo.....i run mine through the brake booster vacuum line....just pull off line and pour bottle slowly into line....sit back and enjoy the smoke show....lol
Definately feel that the throttle is more responsive and smooth. I do this every 6 months
Old Jan 28, 2013 | 04:55 PM
Ryan0260's Avatar
This. And Chrysler combustion chamber cleaner to remove carbon. There is a good write up on here about cleaning the tb. It is easy
Gary Palms2Pines's Avatar
Sounds like they really want to clean out your wallet.
Old Jan 28, 2013 | 04:57 PM
Bronco_Bustin's Avatar
Isn't running that through your intake hard on your cats?
Old Jan 28, 2013 | 04:59 PM
JustTryingToLive's Avatar
i am interested in doing the seafoam treatment thru the lines, but not sure exactly which line. if someone could snap a shot of the correct line, i would be extremely grateful. thanks
Old Jan 28, 2013 | 05:01 PM
notsoricer's Avatar
thanks guys. can i have links to the products just to make sure I'm getting the right stuff? trust me, i know better that to have these guys wring me out, i worked in the business long enough to learn their ways. thanks for the info thus far!
Old Jan 28, 2013 | 06:21 PM
Ryan0260's Avatar
Not any harder than all the burned off oil clogging them
Old Jan 28, 2013 | 06:55 PM
notsoricer's Avatar
so i get some chrysler ccc and spray it where? and i should put the seafoam in the tank? or should i find a better additive? i hear mixed results about seafoam but only good stuff about chrysler ccc...
Old Jan 28, 2013 | 07:22 PM
Ryan0260's Avatar
IMO, the seafoam is good to run through the tank, but when your ready to step up to the big leagues, CCC is where it is. It works best with two people. One person keeps the engine running while the other sprays the contents directly into the throttle body until can is empty. Shut off motor and allow to sit, preferably several hours. Then go drive the shit out of it, get on it etc. May need a second treatment if carbon deposits are bad. The stuff works great
