Maintaining A/C systems.
Old Jun 9, 2011 | 04:23 PM
Dronac's Avatar
Default Maintaining A/C systems.
The AC on my brother's Acura just went out at only 100k miles and t got me thinking. Is there any yearly maintenance that should be done to the AC system? For instance, checking the pressure? Since the lubricant is in the freon, a leak would cause a lack of lubrication and eventually compressor failure correct? Can you gauge how well the AC is working by checking the temperature against ambient temps?
Old Jun 9, 2011 | 04:30 PM
thrshr01's Avatar
The best way to maintain your a/c system is to cycle it once a week to circulate the oil. No need to check the pressure (you'll just release freon). IIRC (haven't worked on A/C systems in a while), a 40 degree drop from ambient is what you should look for (this is air coming out of your vents, not in cab air).
Old Jun 9, 2011 | 04:34 PM
GreenJK07's Avatar
Good to know! I never use my ac!!! Ever....
Old Jun 9, 2011 | 04:40 PM
thrshr01's Avatar
When you turn your heater on, use the a/c. It doesn't have to be for the whole time, but 10 minutes will suffice.
Old Jun 9, 2011 | 04:46 PM
ronjenx's Avatar
The computer monitors system pressure. When it drops, it will cut power to the compressor clutch.
Here is the performance data from the factory service manual:
Ambient Temperature..... Air Temperature at Center Panel Outlet
21° C (70° F).................... 6 -15° C (42 - 59° F)
27° C (80° F).....................7 -18° C (45 - 64° F)
32° C (90° F).....................9 - 21° C (48 - 69° F)
38° C (100° F)...................11 - 22° C (52 - 72° F)
43° C (110° F)...................13 - 24° C (56 - 75° F)
