Manual Transmission Replacement
Old Feb 3, 2009 | 11:00 PM
  #21
Phillie's Avatar
I live in northern Canada where the temperature is below -20 deg celcius all winter and I don't have any grinding issues between 1st and 2. I put the center console air vents down so it will blow hot air directly on the shifter and let it warm up for at least 10 minutes before I start driving. If I don't do that 2 and 4 pops out below -10. The problem is that the inner shift boot is frozen solid and don't allow the gears to engage properly or pops out. Even in warm weather going from 1st to 2 is not smooth at all on the JK trans. I adapted the way I shift by pausing for 1 sec into neutral between 1st and 2 and it's a little smoother.
Hope that helps
Old Feb 4, 2009 | 05:15 PM
  #22
bteeuwen's Avatar
i have my jeep in for this issue right now also,
the trans tech is not really sure exactly what the problem is, and is replacing parts as he goes, so will see what happens, the lady said they would update me as they go, didn't receive a call today, but i am not to worried.
also i had my jeep in for the clutch squeak also and got a new clutch at 15,000km if that helps anyone
oh and i just got my diff fluid changed also
Old Feb 5, 2009 | 03:40 PM
  #23
bteeuwen's Avatar
so an update for you guys i got a call back and the girl said they are ordering all new syncro's and gears and everything for my tranny... havent got a clue why they dont just replace it but ohwell
Old Feb 25, 2009 | 06:05 AM
  #24
Imkman's Avatar
Originally Posted by HuskerRubi
Has anyone had any problems with their tranny grinding and slipping? I took my Jk into the dealership friday for grinding from 1st to 2nd and they informed me that they have to replace my tranny. They don't rebuild the wranglers.
My first response: Please tell me this is under warranty (22K on jeep)!!
They said it was.
Was just wondering if anyone else has had this problem...
You too?!?!?
Mine is at the dealership waiting for a new tranny as we speak. Same problem grid from 1st to 2nd and 4th to 5th and 6th to 5th. The syncros are fucked and we get a NEW tranny! Sucks it happened at 22k for you, mine is at 76k
Did they say the tranny is on back order? That's what they told me... had it in since last Thursday and hoping to have it back next week maybe....
Good luck!
