Mileage still increasing while flat tow, with battery disconnected?
Old Jan 4, 2013 | 06:39 AM
Edge Hawk's Avatar
It's taken me a few times to get the change oil display to reset.
Plus the change oil isn't based on mileage alone, it's an algorithm that takes idle time, miles driven, RPM, engine load.
Old Jan 4, 2013 | 06:48 AM
dallasc's Avatar
Originally Posted by bushpilot
anything PRIOR to 09s have steering locks.
they DELETED the steering wheel lock sometime in MID model year production of 09.
2010+ jeeps do NOT have steering wheel locks.
NEVER tow where the steer wheels can lock, you'll damage the tires if not worse.
once the wheels turn & lock theyll end up dragging (while going straight)....which could over heat them and eventually cause them & the jeep to catch fire & burn
I purchased my jk in April of 09 and found out later that it didn't have steering lock. But thank you for covering my back. You can never be to careful when you consider the damage if you don't.
Old Jan 4, 2013 | 06:50 AM
ronjenx's Avatar
For those who want to check to see if their JK has a steering wheel lock, you have to turn the wheel more than a half turn to find out.
Old Jan 4, 2013 | 06:56 AM
bushpilot's Avatar
agreed ! From what ive read about the 09's, no one has been able to pinpoint WHEN the wheel lock was discontinued.
Old Jan 8, 2013 | 08:34 AM
ThreadHijacker's Avatar
Rather than pulling fuses can't we put the transfer case into neutral to prevent mileage from going up? I thought the speedo and mileage were controlled by input and output sensors on the transmission/transfer case and not controlled by the wheel speed, but I could be wrong. I may have to flat tow the jeep soon so I will have to test it out somehow.
Old Jan 8, 2013 | 08:38 AM
rob_engineer's Avatar
From quadratec:
Old Jan 8, 2013 | 08:39 AM
2009jeepwranglerx's Avatar
Mines am 09 built in 3/09 according to the door jam sticker and does not have the steering wheel lock
Old Jan 8, 2013 | 08:47 AM
Originally Posted by rob_engineer
From quadratec:
Thanks. That's what I was looking for
Old Jan 8, 2013 | 12:50 PM
JK-UTE's Avatar
x2. Good information. Thanks
