The Most Important 1st Modification On The JK
Old 08-23-2013, 03:11 PM
GIJK's Avatar
35"s will if you cut your fender flares or get flat flares.
Old 08-23-2013, 03:17 PM
kdubflint's Avatar
What's the easiest way to cut the flares? I think I've read about ppl using a dremel?
Old 08-23-2013, 03:23 PM
Ryan0260's Avatar
Originally Posted by Legolasies
Just got a 2010 Jk and I'm wondering from experience what would be the most important first mod to place on it. I was thinking a lift kit and some tires, what do y'all suggest?
Take some time to research and make a game plan as to what you want the build to ultimately be. As far as visual impact, a lift, tires, and wheels will change the look completely.
Old 08-23-2013, 03:29 PM
stagedtrip's Avatar
Originally Posted by Ncb
First mod should be replacing all the shitty bolts in the front suspension.
X2 costs 45 bucks, helps prevent/delay/eliminate(in some cases) deathwobble. Also an excellent way to learn your jeep!
Sent from my NSA listening device
Old 08-23-2013, 03:59 PM
falc0n2u's Avatar
Eh, I guess it's better just to save up and get it all done at once
Old 08-23-2013, 04:10 PM
Legolasies's Avatar
Will 33" fit without getting a lift? Cuz if I can get the tires and then work on getting a lift later that will be good for my wallet.
Old 08-23-2013, 04:32 PM
kh202's Avatar
Yup. You can fit 35's no lift on the street too as said above
Old 08-23-2013, 04:40 PM
boopiejones's Avatar
i used a jig saw. worked really well.
Old 08-23-2013, 04:47 PM
kdubflint's Avatar
Default cool
Alright, thanks. I might just wait till i get flares to put on 35's, i was thinking about getting them soon anyways.
Old 08-23-2013, 04:59 PM
kh202's Avatar
Cutting them is super easy man. Flares aren't cheap. Save that money for lift and tires is my advice
Quick Reply: The Most Important 1st Modification On The JK
