My Jeep was shaking at idle speed, but now this problem disappeared
This morning, when I was waiting for signal at a intersection, my Jeep was shaking, not
too crazy, but I can feel the strength.
After the signal turned green, I started driving and the shake went away and I can not
reproduce this problem again. I even tried to stay in idle state for 5 minutes and nothing
happens.
Do I need to worry about it. My JK is still under factory warranty. But if I can not reproduce
the problem, I guess the mechanics can not help me much on this issue.
happens.
This is super super common in JKs. I don't think there's much to worry about. I found in my case that putting shell fuel instead of no name brands did prevent my jeep from doing it, but that's just my personal experience. You can also try putting in some fuel injector cleaner.
Mine has done it about 3 or 4 times over 4 years. I just relate it to piss poor gas or higher ethanol content. When this happen's I usually drop in a can of seafoam into the tank to clean out the injectors & get on the skinny pedal more to blast out any build-up!
But shell is always the cheapest in my area so im not complaining
