Need Help with Alternator Problem after Mud
Old Jul 17, 2008 | 07:33 PM
BrettDez's Avatar
Default Need Help with Alternator Problem after Mud
Hey guys,
Well, my engine has had a loud whine to it comming from the alternator now for a long time. The noise is more annoying then anything else right now. But it's also a worry of mine. The noise is absolutely comming from the alternator on the right side of the engine.
Obviously with my snorkel and vids/pics I post from time to time. I see alot of deep mud and water. I imagine there's mud/water that's gotten into the alternator more than just on one occasion.
This whine has been there for at least several months and several offroading trips. It gets louder with the engine revs, most likely due to the belt spinning the alternator.
My question:
Is this a sign my alternator may die at any moment? Should I replace it now and not have a problem at a very bad time later on?
Is this something a little grease or cleaner sprayed inside may help, and if so, any specific spots to aim into it and what kind of grease/cleaner do you reccomend? Like WD-40 into the "air slots" where the mud/water most likely entered? Or electrical contact cleaner?
Any help is appreciated guys!! And most importantly, is this even a concern? Or just an annoyance with making my engine whine.
Old Jul 17, 2008 | 08:10 PM
muddpuppy01's Avatar
yeap WD-40 into the "air slots" where the mud/water most likely entered after rinsing it off after a wheeling trip
Electrical contact cleaner after everything dries up just to get out anything else that may be in there
Old Jul 17, 2008 | 09:48 PM
RedneckJeep's Avatar
Uhhhhhh...I wouldn't do WD40 unless you want a FIRE. It is classified as EXTREMELY flammable. You might have some success with brake parts cleaner. It is the same chemical compound as electrical parts cleaner and will evaporate completely.
Old Jul 18, 2008 | 03:59 AM
rickl's Avatar
it is an alternator,without it you are walking,if in doubt change it out
Old Jul 18, 2008 | 07:38 AM
BrettDez's Avatar
Hey thanks guys,
I think you guys might be right afterall...I decided to investigate further as recommended and now I am not sure it is the alternator afterall. Could be the idler pulley...I think.
Just to verify, the idley pulley is just below and to the left of the alternator's pulley when looking at the engine from the front? If that is the idler pulley, then I guess I have to replace it.
Sadly, the dealership said they have no time during my days off to do it. And I'm in the military and this is my only vehicle, so I can't drop it off like they wanted me to do. So I will replace it on my own, but I have to confirm that the pulley I see/hear is the idler pulley.
Old Jul 18, 2008 | 07:07 PM
insanegecko's Avatar
Default old school noise isolation
with the engine running and making the noise you chasing, take a long screw driver hold it to the case of the ALT andput your ear to it then move to the housings of the the accessory pulleys....old school stethoscope...or you can for over about 20 buck and buy an automotive one at sears
if you suspect the belt, moisten a rag w brake fluid and run along the face of the belt. This with mosieten and swell the rubber slightly....dont use any petroleum base stuf as oil disolves rubber, i guess silicone would work ok, but its to much of a lubricant and might cause slippage
Gex
Old Jul 18, 2008 | 08:19 PM
Originally Posted by BrettDez
Hey thanks guys,
Nope, that's the tensioner pulley. The idler pulley is on the driver's side.
Old Jul 18, 2008 | 08:31 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
here is the idler pully, they are different for w/ac and w/o ac
moparpartsamerica.com/partlocator/index.cfm?action=getJointLocator&siteid=214583&cha pter=&Sectionids=0,2308&groupid=51824&subgroupid=2 342&componentid=4099&make=17&model=Wrangler&year=2 007&graphicID=WJ07055&callout=2&catalogid=2&displa yCatalogid=0
Old Jul 22, 2008 | 06:37 AM
BrettDez's Avatar
Hey guys,
You were right all along, it WAS the idler pulley. I had it replaced and the engine runs silently again. Thanks for the help!!
