Need help - grinding
Good afternoon guys and gals,
I have a 2013 Unlimited Sport JK which I bought used in 2017. It’s had one previous owner and I’ve had zero issues with it since I bought it. Today however, my first issue has come up.
I started my Jeep and heard a loud metallic rattle/grind that last for about 10-15 seconds and then went away. I killed the motor, waited a few moments and restarted. Not a sound. Drove 20 or so miles to my next stop with no issues. After I fueled up I started her up and the noise came back except it lasted nearly 30 seconds and continued after I put the Jeep in drive. I suspect the starter is not fully disengaging but I’ve never owned a Jeep before so I’m not sure of all the quirks that these rigs have.
Got her home without issue, let it sit for an hour and then restarted. The grind came back and continued while I let it idle in park. It didn’t go away until I shut it off. I saw in a separate forum that sometimes disconnecting the battery for 10 minutes will reset the computer and sometimes fix the issue. I followed that advice and she started up quiet and smooth like she always does. I still suspect the starter but am unsure. My previous rig was an ‘86 4Runner so this Jeep thing is still very new to me.
Has anyone had a similar experience or any wisdom to pass on? Thank you in advance!
highadventure18 (05-14-2019)
I'd crawl under quickly and listen near the starter to confirm. The 10 min-disconnect-reset sounds like a waste of time. If the noise is the starter not disengaging, it's likely the starter itself. One can get a voltage reading on the small wire to the starter and prove it's not getting power even through it's engaged and making noise, but for an intermittent problem sometimes part substitution (replacing the starter) is the best method.
Stay in touch,
Stay in touch,
Thank you for the replies, guys!
I couldn't lay down without trying it again. Fired up and that awful grind came back loud as hell! I think I'll be taking the Wife's car to pickup a starter tomorrow. Is it worth getting a Chrysler/Jeep made starter is a NAPA/O'Riellys/Autozone throw down good enough for these rigs?
When I replaced mine, the only one I could get my hands on was an Autozone reman. Everyone else was saying a full week for it to come in. Mopar said a week, plus $300 more.
It is a little louder than the factory starter, but it's been going strong for over a year.
