need help P0100
Hi guys, I need some assistance with a DTC p0100.
2k7 JK, 62ish- k miles. I was throwing a code for the right lower O2 sensor as well, but I replaced it and the code cleared. I did notice the intake hose was loose, and one of the clips on the airbox was not clipped ( thanks Texaco... ), but both of these were fixed, and I reset the codes using my reader. I also looked at the intake temp sensor, but it seemed ok. I've driven about 100 miles, no noticeable loss of power. Only the p0100 comes back, as soon as I start the engine.
Since there's no MAF on this thing, what else should I be looking at ?
From: Apple Valley, California Good ole Mojave Desert.
didn't see this exact code but maybe this will help a little. p = power train
http://project-jk.com/jeep-jk-write-...what-they-mean
Not much - that's kind of the problem. even on the page you just posted, p0100 isn't listed, because it's not a jeep specific code. It's a generic ODBII MAF/MAP code.
Since there apparently isn't a MAF sensor, it makes it hard to know what wiring to check or sensors to look at. I was hoping someone else had run into a similar issue.
I've replaced the 02 sensors, tightened the stock CAI hose, replaced the air filter, cleaned the intake air temp sensor, cleared the codes, and done a 100+ mile drive.
could it be the intake air sensor ? Maybe my obd computer's just fried. I can't believe that I'm the only one that's seen this error - the odds are against it. If I cant solve it, i have to go to the stealer so I can pass emissions and get my tag, and I hate going to the stealer for something that I later find out I could have fixed myself.
As for passing emissions, how can they ding you for a code that doesn't apply to your JK? Like you said, it doesn't have a MAF.
