Need some help on basic maintenance
Old Sep 17, 2009 | 01:08 PM
Locklain's Avatar
Originally Posted by Jiblet
**snip**
$6 plugs... must be E3s From what I have read most folks haven't changed plugs unless they were getting a rough idle. And only changed wires if there was a problem like sparking or something.
$58 X 6= fail
**snip**
Just as a heads-up (don't want to derail) don't fall for the hype that is the E3 plugs. I am running them in my Jeep now and have not noticed anything different. Have had them in for two tanks and no improvement to MPH, idle, or general operation. I am always a sucker for this kind of stuff and it doesn't matter how many times I get burnt. . . Stick with the recommended plug.
Old Sep 17, 2009 | 01:41 PM
Dwikto's Avatar
They are Bosch Double platinum (which actually have four arc towers on each plug) not E3s guy at pep boys said these are the best, and theyt could not get e3s
Old Sep 17, 2009 | 04:11 PM
Adam3612's Avatar
Originally Posted by dirtyjkwrangler
is there an easy way to check the fluid in the transfer case? I just bought the jeep used, and although it doesnt look like it's been off road at all I'm not totally sure if 4wd has been used frequently or not.
ha yea. Mine's in the mail. Hopefully I'll get it today.
Other than pulling the drain bolt in the transfer case I dont think there is a way to check, you could pull the fill bolt and use a zip tie or something but I dont know if that would work. Check your skidplates and stuff, if they look beat up and scratched the previous owner more than likely wheeled it a bit. If all else fails go to the dealer and ask them if they changed any of the fluids before they sold it to you.
Old Sep 18, 2009 | 06:16 AM
Jiblet's Avatar
There nothing really to check, its not the level* so much as the quality of the ATF+4. By that I mean is it burnt smelling, cloudy/contaminated, unusual amounts of metal flakes or bits. Stuff like that. For the trouble of getting down there to check it, just change it.
*(yes, if the level is low you have a problem but that probably means a leak or crack or something but I am assuming the T-case is intact and functional)
