new eng for 09
Old May 24, 2011 | 10:10 PM
deltaneo1's Avatar
Originally Posted by JKlad
I noticed the OP said he's had the dry-start rattle from new. Although many people say that it's not harmful to the motor & all the noise is just the lifters banging around until they get oil pressure, the fact is that the motor is running at 1500RPM (the speed that the computer idles the motor from cold start) with no oil pressure for 2 or 3 seconds. Although the bearings will have some residual oil film on them at startup, after a few seconds running at 1500 RPM without ony more oil getting to them damage will be done. This damage to the bearing surface may only be slight and microscopic, but after repeated cold starts over time it all builds up, and it seems to be no coincidence that 40K miles seems to be the common mileage that these motors tend to all spin bearings & throw rods (40K miles= about 2 years of average use of mainly short daily to/from work trips with some weekend driving thrown in, and around 1400 dry starts).
While many people who've had bearings let go have also had oil burning motors that have caused the sump to run dry & thus starve the oil pump causing the bearings to run without lubrication, others like the OP have don't have this oil burning issue & have still spun bearings. It's also interesting that everyone who's had an oil analysis done shows reults with very high copper levels that have been attributed to the camshaft bearings, and camshafts are known to be very susceptable to wear at cold startup.
Well dry starts are bad like you said maybe a thicker oil will help. I know that BMW uses a 0w-40 for this reason and they don't need oil changes till like 10K or 20K don't remember. I might start running 10w-30 for this reason but with a lift time warranty I think I will be fine!
Old May 24, 2011 | 10:48 PM
JKlad's Avatar
Yeah, dealers where I am use 10W30 & many people who do their own changes use 0W40 full synthetic, which (although expensive) is probably the best all-season grade to run in the JK as it's thin at cold winter temperatures to flow easily through the pump & oil galleries at startup while still maintaining film strength at extreme operating temperatures. Chrysler specifies 5W20 for the US market purely for fuel economy reasons so they can achieve their government-mandated CAFE targets.
Old May 25, 2011 | 04:48 AM
pirate's Avatar
I've been running 5w30 synthetic for every oil change. I like that grade thin enough for winter but good for the summer as well. So I don't think its related to oil. On a side note how many eng have been replaced on synthetic oil and conventional oil? Maybe I'll make a new poll.
Old May 25, 2011 | 06:27 AM
lopezv123's Avatar
I know everyone had been looking at oil type and grade as a potential cause of the engine problems all of these JKs have but has anyone considered the possibility that it's a fuel problem? I've heard of ethanol tearing engine components up (especially the older designs). The oil consumption problems are merely a symptom leading to engine failure but the root cause is ethanol. This had been a huge issue for 4stroke marine engines as well. Maybe worth polling people with engine problems about what type odlf fuel they use? Just a thought.
Old May 25, 2011 | 07:57 AM
deltaneo1's Avatar
Always run super 93 Octane fuel! I don't know anyone running that E-10 or ethanol and would never run it on any car that isn't a flex fuel car!
Old May 25, 2011 | 12:37 PM
pirate's Avatar
You don't always get a choice if you run enhole blended fuels. If I know it's blended I stay away for it as best as I can. I've run it before and got horrible miliage 50-70 km less to a tank.
Just got back from the dealer and they have all the parts in stock now so maybe soon I'll have my jeep back.......
They are saying the are replacing the crank and bearings, as well as all of the connecting rod bearings. So we'll see how that plays out.
Old May 25, 2011 | 03:03 PM
JKswede's Avatar
I have an 07 that started ticking a couple of weeks ago. It spun a rod bearing and damaged the engine. I need a total replacement at a cost of $4300 out the door. No warranty since it came with a 3 year 36000. Had i waited 4 more months in 07 it would have come with a lifetime warranty. The vehicle was bought brand new and it has 61000 miles on it. Oh, well....
Old May 26, 2011 | 03:10 AM
lopezv123's Avatar
All fuel manufacturers in the states are allowed to add as much as 10% ethanol to any grade fuel without calling it a flex fuel. You need to check the tag on the pump to be sure. Stations have to post on the pump if they're using an ethanol blend.
Old May 26, 2011 | 06:16 AM
drumnatural's Avatar
Running 93 is excessive IMO unless u have a tuner that requires it. I do run 89 though just to help avoid pre-detonation.
Old May 26, 2011 | 08:03 AM
deltaneo1's Avatar
I Don't see to many blends at 93 that is why I get it. Things in the states must be different since I have been there... But will be back in 3 months. I ship my Jeep in 1 1/2 months back to the states. Most the gas I get is on-post so don't know about blends with it here in Germany! It doesn't say anything about blending at all! Just E-10 and super 93.
My wife has filled it before off post with 89 and I could tell the difference. Seamed to stumble on idle a lot. She didn't even tell me I just looked at her and said the JEEP is running shitty and what kinda gas you put in. That is when she told me!
