New to Forum, 1st question!!
Old May 23, 2009 | 12:19 PM
Cajun I's Avatar
Default New to Forum, 1st question!!
Hey guys, new to the forum! Just bought a new 09 Rubicon 2 dr. First question is how large of tires can I put on the stock suspension with out lifting? Thanks for your help in advance!
Old May 23, 2009 | 12:22 PM
pastorsteve's Avatar
Welcome to the group. You'll get a lot of answers on this including "do a search" as it is one of the most frequently asked questions. It depends on your terrain, driving, wheels, backspacing and .... So, I believe, 33's is generally the accepted answer but i'm sure if you do a search you'll find dozens of threads answering this for you in different ways.
Old May 23, 2009 | 01:01 PM
Mark Doiron's Avatar
Welcome to the forum, Cajun 1! You should definitely visit the FAQ: It has the answer to your first question--and probably many more.
JK-Forum FAQ
Old May 23, 2009 | 04:10 PM
Mr.ZAP's Avatar
Very true.. If you trim the fender flares you can fit 35s, otherwise 33s
Old May 23, 2009 | 05:02 PM
paramaniac's Avatar
welcome to our world!
pastorsteve said it best..... mark Doiron backed it up.... search and find the FAQs, all your "Newbie" questions can and will be answered....
and dont forget to post up some pics!
Old May 23, 2009 | 05:20 PM
mkjeep's Avatar
Welcome to the forum! St. Amant isn't far from me . La. 4x4 outta Baton Rouge is a great club to hook up with. They do alotta rides in our area.
Old May 23, 2009 | 06:25 PM
nthinuf's Avatar
Didn't see the location mentioned or linked, but the FAQ is stickied at the top of the Modified JK Tech area. Real good place to start for the basics, then search for an information overload, that'll give you all kinds of questions to ask...
https://www.jk-forum.com/forums/showthread.php?t=18617
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler?
A: The largest tire size that the factory recommends is a 255/75R17 (which comes standard on Rubicon models) or a 32x10.50. However, there are many Jeep JK Wrangler owners who are currently running as big as 285/70R17 or 33x10.50's with little to no rubbing issues. (if you go to a 12.50 width, you'll probably need wheel spacers or aftermarket rims)
Q: What is the biggest size tire that I can I fit with a 2.5" Budget Boost?
A: 33" without any problems and 35" tires with only minor rubbing at a full flex. Depending on how wide your tires are, you may experience some rubbing at a full turn especially if you did not install an adjustable front track bar and/or are still running factory wheels which have 6.25" of back spacing.
Q: What is the biggest size tire that I can fit with a 3" lift?
A: 35" tires and depending on what lift kit you have, you may still experience some minor rubbing up front at a full flex and when turning.
Old May 23, 2009 | 06:31 PM
SHIT GREEN MACHINE's Avatar
Welcome. I put 33s and didn't feel I had enough clearance. I actually rubbed backing out of my drive way while turning to hard. So I put a 2" BB lift.
Quadratech has a spread sheet you can look at that is very basic.
Old May 23, 2009 | 07:14 PM
This is completely irrelevant, but nice username.
Old May 23, 2009 | 07:30 PM
Thanks Can't deny Rescue Green was named wrong
