No Question is Dumb-Except This One-Soft Top ?
Bought my soft top off Craigslist and I printed some kind of half a$$ directions off the internet. Install went ok, few minor issues, but they were all resolved from fellow members on this board. I've been installing the side windows first. I can eventually get the tailgate bar and rear window on, but whats the correct order? Thanks fellas.
Thats what I've been doing. I don't know how to do the rear window. Does the rear window go in tailgate bar first then zip it up? I usually have to remove the actually back strap on the driver's side to get my fat fingers in there to start the zipper. Everytime I do it I know there has to be an easier way.
Originally Posted by westchester
I put the rear window back first, as the zip is more troublesome to start and slide, and best done before the side windows pull the corner sails tight.
realy doesn't matter how you do it, I'm differant every time as others have said
you MUST slide the rear window in FIRST on the tailgate bar before you try & zip it up, then clip it on the tailgate area's where it belongs & then zip it up
side windows, it's best to start the zipper at least 1/4 of the way close, then put it under the velcrow ( top), then the front half in the rail, then finish zippering & velcrow, do the bottom plastic strip LAST...this works for me everytime with NO hassel
I zip the rear window in, leaving about 3-4 inches before the end, slide the tailgate bar in & fasten to the clips, then finish the zipper.
