Sponsored by:
Sponsored by: DashLynx
no tow package. no wiring?
Old 01-03-2011, 08:51 PM
Mreroe's Avatar
Default no tow package. no wiring?
I do not have the tow package but am planning on buying a receiver and hitch. When rotating my tires I took a quick look and couldn't find any trailer wiring under the jk at all. I know on my previous titan (no tow pkg either) it came with the wiring but I had to buy some relays for the turn signals to work. Does anyone know if I have to buy a wiring harness or relays or anything?
Old 01-03-2011, 08:54 PM
burnout88's Avatar
You have to add it the factory tow harness. It's only 40 bucks.
http://www.justforjeeps.com/trtowwihakit1.html
Old 01-03-2011, 08:55 PM
ronjenx's Avatar
A plug'n'play wire harness can be purchased from Quadratec.
09jaykay's Avatar
Get the mopar wiring harness, Plugs into the driver side tail light and then runs to the hitch super easy to do.
Old 01-04-2011, 04:46 AM
Mreroe's Avatar
Ok that's not too bad. I know with the titan just those two little fuse type relays were over $150. Good to know im not facing something like that again.
Old 01-04-2011, 05:39 AM
Mixilpidilstick's Avatar
I bought mine off of ebay for less than $20.
Old 01-04-2011, 08:19 AM
conwaybiker's Avatar
I bought a Rugged Ridge hitch and wiring harness. Everything fit like a glove.
Old 01-04-2011, 02:31 PM
NH-JK's Avatar
I got my 4 pin at the dealer for $40 bucks.. Its plug and play... Unbolt your drivers side tail light and it plugs in.... The 7 pin is more money but you have to splice wires...
Old 01-04-2011, 02:58 PM
FFEMTBIKER's Avatar
That's where I got mine. Under 20 bucks super easy to install.
Old 01-04-2011, 03:55 PM
mfrank84's Avatar
My new JK didn't come with a hitch either. I bought a hitch (Curt brand) and a wiring harness. The hitch took only four bolts to mount with pre-existing holes in the bumper. Took ten minutes to do. Instructions said to drop muffler from the rubber muffler support for extra room but it wasn't necessary. Was able to move the muffler enough to get the only bolt obstructed installed easily. It took longer to find my screwdriver to remove the driver side tail-light than it did to install the wiring harness. I ordered the B&M Transmission Super Cooler, gathered all the misc. parts I need, and will install it this Saturday. Class III hitch and harness were approx. $130 with free shipping.
Quick Reply: no tow package. no wiring?
