noise after spark plug change
Hello all,
I just did a spark plug change on my 2013 jeep jku 6 speed due to a misfire in cylinder 2 code (p0302). I have noticed a noise like a knock/tick while in idle and a little while on the gas. it idles at a good rpm just sounds rough. are there any thoughts as to why this is happening? I believe it could be because a possible coil pack isn't fully engaged with the plug and the arc is jumping but there are is no longer a check engine light and no code for a misfire. would this problem throw a code for misfire?
Thanks for helping!
Thanks for helping!
I used Champion Iridium- Boxed - RER8ZWYCB4, I got them from advanced auto parts and seemed to match the dealership plugs would they be different in any way and i also gapped them correctly to .043
I assume you pulled and reinserted the wires just to make sure they were seated properly? My daughter had a Mitsubishi Eclipse that was idling rough. Turns out that one of the plug wires wasn't seated well.
A ? how many miles on your 2013? I believe the coil packs are held in by a retaining bolt; so how could it not be properly seated on the plug? Also you did the right thing going with the Champions (factory plug).
jmoore29 (04-03-2019)
Same thing with wires, but it sounds like the 3.6L doesn't have those.
80,000 miles on the jeep and each one is seated properly after going and checking each plug again which was a pain having to take off the plenum again... but everything looked be in order and torqued back to factory spec. after driving for a few minutes after the p0302 code popped back up. I'm thinking it could be possible injector or piston problem at this point because i switched the coil packs to make sure that wasn't the problem either.
Are you certain you are not covered by the cylinder head problem that happened in some 2012 and 2013? Chrysler extended the warranty on all 2012 and some 2013 jeeps to 150,000 miles due to a cylinder head problem. Some people with that problem got the same code you have, as well as the ticking sound.
