The noise is not Dry-Start, What can it be?
A little while ago I started this thread asking about a start-up noise:
https://www.jk-forum.com/forums/show...oise&p=2316039
Some people suggested it may be the famous and dreaded dry start caused by a bad anti drain-back valve in the oil filter. so I called Donavee Jeep in Placentia and the service manager says one way to verify the anti drain-back valve in the oil filter is when you remove the filter, oil will flow out of the engine from the threaded pipe that the filter screws on to If it does then the valve was working correctly. I decided to also take the good advice in that thread and try a Napa Gold filter and Royal Purple oil. I let the jeep sit for 2 days to give the faulty filter valve a chance to drain and then I went to chance the oil. When I removed the Fram filter lots of oil flowed out of the engine meaning the anti drain-back valve was working just fine. I figured that since I was already dirty I would complete the oil change seeing as how the royal purple is supposed to be better. It has now been 2 days and the engine is still making the exact same noise every morning.
This tells me the noise has nothing to do with dry start. Does anyone else have any ideas as to what the noise is?
Question: Did any oil came out the oil filter ?
If the answer is no. The antidrain valve was not working, It did not hold oil in the filter. Is like an Air pocket if the filter is empty. Once the filter is fill at start up (1-2 seconds) the noise (dry start) stops.
Yes the filter was quite heavy with oil and it took a while for it all to drain out in the catch pan. Also the center pipe that the filter threads on to leads toward the top of the engine and a really good amuont of oil came out of that. if the anti drainback valve was bad the oil would have flowed through the filter and back into the oil pan in the the two days the jeep sat in my garage.
fram filter and warm weather ! kinda like a ehhhhhhhh sound after you turn ignition right ? only other thing i can think is maybe its the starters they used ! maybe the starter stays engaged just a tad longer than it should ! but i havent a real solution i hope that was the end for mine! i dont like anything mopar ! infact im thinkin of changing other fluids soon too just in case its cheap mopar chrysler antics! not impressed with clunky noise when shifting sometimes sounds like transfer case clunky noise like theres play in the gearing ! prob thin gear oil maybe! i only have 2,400 miles on my 2011 and its done it from day one so im not concernd just like the ticking noise in engine from day one ! so i think its prob not going to hurt anything id just run it till it breaks and then youl know for sure !
I wonder if it is something totally different like valve lifters, power steering pump etc?
I have had this since day one of ownership. I have found the solution to fixing it...
Just try to get video of your start up with your cellphone and it will never grind...
I have recorded every startup for the past week and it hasn't done it once.
I have been turning the ignition to the ON position for a few seconds before startup, thinking maybe that would get the oil pump going (don't know if it is driven seperate from the engine). Haven't had the problem since doing this ????
It really sounds like the starter is grinding, like mentioned above, maybe staying engaged too long...
Maybe I will need to take it into the dealer to look at it. I have the lifetime warranty but with the mods in my signature I am sure they will try and play some games to get out of taking care of the customer.
Hello to all:
Same sound here as well. Also feels like a rumble effect, especially if not started within 3 days or more. Def gets worse as days go by without starting. I also get the oil light within 3 days of not starting. I have some friends who are mechanics and they told me as long as you are not lossing oil and the oil and filter are clean with no burn smell, all is ok. Also was told that these new pressure switches they have a tendency to stick , causing the oil light to stay on longer. He serviced quite a few Wrangler's in his lifetime, and told me not to worry.
That might all be true, but that metal to metal noise that the op and others on this thread described, can not be of any good news. That just sounds like a future repair bill in the future that can be prevented.
What is really crazy , is when I recently changed my oil-- non synthetic, with a new Mopar Oil Filter, the noise did not come back until a week later. Eventhough some folks did not see a change, I am going to try the Napa Gold Filter,, which I beileve is made by Wicks ???. Other good ratings were Donaldson, and MotorCraft.
I change my oil and filter every 3,000 miles, due to trying to keep the 3.8 engine alive for many many years...lol
I agree with everyone on here, something is not right mechanically or just the design of the 3.8 Liter is very bad.
P.S.- Has everyone notice even the filter itself is on a angle . Open your hood and look down, it is leaning more toward the serpentine drive belt pulley,,,weird...
SLIM
SLIM
