Not again!!!!!
well, Jeep is going back in for service for repeat issue...a year ago i had cold air coming from both left side air vents and hot air from the right side. After replacing heater core and finally replacing the entire blower motor housing ( contains the blend door which was broke? ) the problem is back again....
could you guys pleas comment on whether you have cooler air on the drivers side or if you have blazing heat equally coming out on all vents. It doesn't matter which position the selector is in either and even the single defrost vent has hot air on the right and cold air on the left?
i just want to understand if this a "Jeep thing " i have to live with or if i have a seious issue.
thanks
thanks
got Jeep back today...heat issue better but not 100% IMO. New rad installed, heater core flushed ( said was partially blocked???they just replaced it 12 months prior ) they said to monitor heat.
thanks
thanks
Just brought the Jeep in for the same damn issue again.....my Jeep is officially now out of the bumper to bumper warranty and i still have the same issue!
Dealer just called and said they are replacing the Heater Core again
.....fully covered as it is an on-going unresolved issue.
What happens if they can't ever fix it?
.....fully covered as it is an on-going unresolved issue.What happens if they can't ever fix it?
