Not again!!!!!
Old Oct 6, 2011 | 09:25 AM
SebasCbass's Avatar
Old Oct 6, 2011 | 09:57 AM
jeeperjkjeeper's Avatar
Originally Posted by jeeperjkjeeper
well, Jeep is going back in for service for repeat issue...a year ago i had cold air coming from both left side air vents and hot air from the right side. After replacing heater core and finally replacing the entire blower motor housing ( contains the blend door which was broke? ) the problem is back again....
could you guys pleas comment on whether you have cooler air on the drivers side or if you have blazing heat equally coming out on all vents. It doesn't matter which position the selector is in either and even the single defrost vent has hot air on the right and cold air on the left?
i just want to understand if this a "Jeep thing " i have to live with or if i have a seious issue.
thanks
Originally Posted by SebasCbass
guess i should have included original post for you.
Old Oct 6, 2011 | 02:33 PM
DonP's Avatar
Im going through the same thing but they do not want to honor the warranty i have had the problem for 2 yrs. im at 36488 mi. i
Old Oct 6, 2011 | 02:54 PM
knnphillips's Avatar
The problem with my AC and heat is the selector doesn't do anything it always blows out of the vents. Ugh!
Old Oct 21, 2011 | 04:35 PM
thanks
Well i got the Jeep back from the dealer today for my never ending heater core/blend door saga.
They replaced the heater core ( for a second time ) and said that it was corroded /rusty and plugged..WTF!!! They had no root cause explanation but for some odd reason changing the heater core solved my issue again ( for now ). The heat is blasting from all vents at the same temp......i give it 3-4 months and i will be back in there again complaining.
Jeep is now out of warranty period but i have a pretty good dealer and they covered all costs due to it being an ongoing problem
i'll keep this thread posted
