OEM Wheel Stud
Old May 10, 2007 | 07:41 PM
SteelBlue07's Avatar
Default OEM Wheel Stud
Does anyone know the correct pattern for OEM wheel stud?
I bought spacers form a guy online on previous vehicles and going to go with him for the JK. The price is $20 cheaper a set also. I think It is 5 on 5 (127mm) as they show them for 99 newer grand cherokee. They also offer 5 on 5 (100mm) and 5 on 5 (135mm). Am I correct with the (127mm)? Thanks
Old May 10, 2007 | 07:50 PM
IGOFSHN's Avatar
Not sure the MM but it is 5 on 5, 1/2x 20 for the lugs.
Old May 11, 2007 | 03:53 AM
Renegade's Avatar
Your terms are conflicting. "5 on 5" means 5 bolts on a 5" diameter circle. Mixing "5 on 5" with various other measurements is confusing. With that said, 100mm=3.937in; 135mm=5.315in; 127mm=5in. So, it appears that the 5 on 127mm would be the equivalent of a 5 on 5 bolt pattern, which is what the JK uses.
Old May 11, 2007 | 08:34 AM
Default Thanks
You are correct. With closer looking at he site I notice what you are talking about. Thanks for the help.
