oil change after 2500 miles....wtf?
Old Mar 23, 2011 | 02:13 PM
blue project's Avatar
Default oil change after 2500 miles....wtf?
I got my first oil change about 2500 miles ago when it told me to. I a running sythetic now. My little sticker from the oil place says i have 500 more miles before they recommend another one. My "change oil" light came on...wtf??? Shouldn't I be able to got at least 3000 miles possibly longer with the synthetic?
Old Mar 23, 2011 | 02:19 PM
Abacabb's Avatar
Check your oil. Most Jeeps eat up oil.
Old Mar 23, 2011 | 03:01 PM
aermotor's Avatar
I go 5k in mine and the light doesn't come on before that.
Old Mar 23, 2011 | 04:54 PM
Dralphy's Avatar
That's just an indicator for you to change it when it hits its "change me now" mileage. Usually if you take it somewhere they will reset the computer, but if you want to cut it off:
Turn your key to the ON position, do not start it.
Press the gas pedal down 3 times, then turn the Jeep off.
Should do the trick
Old Mar 23, 2011 | 05:03 PM
viking's Avatar
Never ever seen that light come on. but I do change my oil religiously every 5,000 kilometres .
Old Mar 23, 2011 | 05:09 PM
Red Wings's Avatar
Mine came on the first time at 2500 miles on the nose, I changed and reset it. It just came on again at 5000 miles (an additional 2500) on the nose. I must be a very consistent driver.
Old Mar 23, 2011 | 05:11 PM
Bradlybob's Avatar
Veteran: Navy
I think I read somewhere that the oil change interval is determined by the computer that takes into account several variables such as how you drive, short trips/long trips, run hours, cold starts, etc. Mine doesn't follow any set mileage, it just pops up at random times. If I'm using dino oil I follow the recomendation of the puter but if I'm using synthetic oil I'll just reset it and change it the next time it pops up.
Old Mar 23, 2011 | 05:16 PM
tazzman121's Avatar
I never have seen that light. I switched to syn oil at 3k and change evey 5k since.
Old Mar 23, 2011 | 08:28 PM
sikjeep's Avatar
Mine comes on every 2500 miles, I change it every 5000 miles
Old Mar 23, 2011 | 11:50 PM
enwhypetey's Avatar
My first light went off at 2300 miles and changed it....after that every 3000 miles until i hit 30000 when it went back to 2500....i reset it and gauged it myself for this last change at 33000 where i switched to synthetic
