Oil Change Notification?
From the Owners Manual:
Change Oil Message
Your vehicle is equipped with an engine oil change indicator system. The “CHANgE OIL” message will flash in the instrument cluster odometer for approximately 12 seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty-cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
From the Factory Service Manual:
The change oil indicator gives an indication to the vehicle operator when a duty-cycle algorithm contained within the software of the Powertrain Control Module (PCM) determines that a recommended oil change interval has been attained.
Change Oil Message
holy crap....I've gotten my oil changed twice....both at 3,000 intervals....I guess I didn't even give it a change ta beep at me?.......I guess I'll never know when ta change my oil now......
Mine use to go off all the time in between oil changes but thats probably cuz the guy at the dealership didn't reset mine when i get it done. now a days it doesn't so im guessing who ever changes my oil resets it.
Does anybody know how to turn the chime off for good. I am tired of listening to it. I do a lot of my own maintenance, and had planned on changing the oil tomorrow, and having a friend clear the warning, but is there a way to competely turn it off?
Does his reference to the skinny pedal mean the accelerator pedal ... so, then, the procedure is to turn the ignition on and depress the accelerator pedal three times?
I watch the color of my oil to decide when to do it...but I don't go over 5,000.
