Oil Filter Small
Old Apr 27, 2008 | 04:29 AM
jeepster2828's Avatar
Default Oil Filter Small
I went to get oil and filter to change my oil.I notice that the oil filter i got is alot smaller than the one that's on there.Are all the oil filter small or did i get the wrong one.
Old Apr 27, 2008 | 04:39 AM
lawsonj3's Avatar
My guess is it wrong. I would go back and double check. There is other info on htis site about different filters. I believe that you can actually get a larger filter.
I used a Carquest Filter (made by Wix) that was identical in size to the stock.
Old Apr 27, 2008 | 04:52 AM
RedneckJeep's Avatar
Some aftermarket filters differ in size from factory filters. If it will fit the threads on the filter boss and the o-ring will seal against the boss it will work. That is, of course as long as there's room around the outside of the filter for it to fit.
Old Apr 27, 2008 | 04:56 AM
pearl-drum-man's Avatar
Sounds like you may have the wrong filter if there is a signifcant difference. Did you use the reference book at the auto parts store to find the part #? The one oil change I did myself the filter I bought was identical to the MOPAR one.
Old Apr 27, 2008 | 07:55 AM
TINMAN080's Avatar
Default check the box
I've puchased oil filters at the world's largest retailer that were in the wrong box, another time I got a used filter that had been drained and returned in the new box. YES I open each and every one now and CHECK while I'm in the store. When W-M gets screwed I think they must just stick it on the shelf and pass the screwing on to someone else..... Ya gotta laugh!
Old Apr 27, 2008 | 08:03 AM
Lorrel's Avatar
I agree that you may have picked up the wrong size filter.
As far as using a different size filter than what is recommended by OEM, be careful. The OEM filter has been spec'd to the engine. Although some oversized filters will fit, and some posters have recommended using these, you should keep in mind the difference in bypass spring pressures as this may dramatically affect the way your vehicle's oiling system operates. Check with the manufacturer for exact bypass spring specs.
Old Apr 27, 2008 | 04:49 PM
I just now saw you posted the new filter was SMALLER than original. I thought it was the other way around when I first replied. Yeah, sounds like you got the wrong filter.
Old Apr 28, 2008 | 03:08 AM
Mark Doiron's Avatar
Just to suggest a possibility I didn't see in the thread, yet: Is the old filter stock? Is it possible that you're working on a vehicle where someone may have installed a larger filter, and now you're getting the "correct" (stock) size filter? I'm asking because the filter that comes stock is pretty small.
Old Apr 28, 2008 | 06:44 AM
Default filter
First l would like to say thanks to everyone for there help.I bought the jeep used and the filter that was on it was a mopar one.I went to two different auto stores and this is what i found.The KN filter and the puralator one was the same size.The fram one was half the size of those two.Anyone else seen this.
Old Apr 28, 2008 | 07:33 AM
myorbital91's Avatar
I use Mobil oil filter M1-209. It is slightly larger than the stock one-if they made a larger one I would run that.
